Canon image class 4150 "reset paper again & reset toner again".
Greenie
I have a Canon printer/scanner 149200 Image Class 4150 Super GS. There was a paper jam and I removed almost a full piece of paper and then a 1" square piece of paper. Now the screen is telling me to "set paper again and set toner again" and of course I can't print anything. What do I do to activate these settings?
1 REPLY 1
This usually means there is still something stuck or present in the machine.  What I would do.
Power off printer.  Open every door or access point.  If it has a duplexer on the baclk, remove it and inspect.  Open the scanner cover and ADF, inspect all areas for ripped paper.  Remove toner and check it's holder and surrounding areas for anything foreign.  Put everything back together cafefully, check the paper feed tray, fan pages, reinsert and power up.
There is likely something still inside.  Keep looking.
