12-18-2022 04:04 PM
I setup my printer for "email to print" so I can email a PDF or DOC file to the printer and have it printed. I setup the POP and SMTP accounts properly and created a special printer email address on my email server, and verified that I can Scan and send to an external email. However when I send a PDF to the printer via the printer email address, the email and PDF is received - I can see it in the Rx Job Log of the web UI - but it does not print and shows an Error Code #818 which is: "The received data is not in a printable file format". According to the "remedy" for this I am supposed to "Ask the sender to change the file format and resend the data". This does not make sense since it is a PDF which is an acceptable format. I verified that the PDF is not corrupted and also sent a PDF as an attachment from several different email accounts, all with the same error.
Help Please!!! I need this to work and can't find any answers on the web. Has anyone got this to work?
Thanks!
Meghan
12-18-2022 07:17 PM
Greetings Mehgan,
What OS (Windows or MAC, version and build) are you using the printer with?
More importantly, what application or program are you using to create .PDF's with?
~R5 C (1.0.3.1) ~RF Trinity, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring
~6D2 (v1.1.1) Retiring ~EF Trinity, others ~DxO PhotoLab Elite ~Windows10/11 Pro ~EVGA RTX 3080Ti FTW3 Ultra ~ImageClass MF644Cdw ~Pixel6 ~CarePaks Are Worth It12-19-2022 09:09 PM
Hi Rick,
Using Windows 10 to send the email to the printer. The PDF was created using Microsoft Word using Microsoft Print to PDF driver. I think I know what you are getting at - I'll try it with a PDF that was created by something else.
Thanks!
M
12-20-2022 08:58 AM
Unfortunately.... that did not work. I tried different PDF files from different sources, a DOCX file, a JPG. All of them when received at the printer give me this code #818. Also tried sending the file from two different email clients, but no luck.
12-20-2022 09:54 AM
Lets try a different way. Here is a link to the Printer's User Guide. Please point me to the feature you are trying to use:
Here is a .PDF version of the same guide of that is easier.
imageCLASS MF735Cdw / MF733Cdw / MF731Cdw / MF634Cdw / MF632Cdw User's Guide (c-wss.com)
~6D2 (v1.1.1) Retiring ~EF Trinity, others ~DxO PhotoLab Elite ~Windows10/11 Pro ~EVGA RTX 3080Ti FTW3 Ultra ~ImageClass MF644Cdw ~Pixel6 ~CarePaks Are Worth It12-20-2022 10:14 AM
Hi Rick
The links you sent me don't provide any details of setting up email to print. This one does:
https://oip.manual.canon/USRMA-1738-zz-SS-enUS/contents/SS735_setup_0050.html
As mentioned earlier, the printer is receiving the file fine via email. And I can also scan to email fine. So the POP and SMTP settings are correct. For some reason it just does not seem to recognize the file
