01-27-2023 11:18 AM
Looking for some help with a paper jam problem during maintenance function.
I can run the "clean fixing assembly to reduce back side stains", however I must run this option several times before the paper is clear of smudges. When I then try to run the second option "Clean Fixing Assembly" paper jams every time and is a real pain to get all of the paper out of the carrier assembly. The print quality has generally gone in a downhill trend over the past few months so I'm ready to put this one in the recycle bin, however it's only 3 years old.
Any suggestions?
Thanks,
Tom
01-27-2023 08:54 PM
Has the black toner cartridge been replaced lately? 🤔
01-28-2023 10:08 AM
Yes, replaced the black cartridge a few weeks ago however the problem started before replacement.
01-28-2023 08:52 PM
The need to run the first process multiple times to eliminate smudges could be indicative of a bad toner cartridge. As a course of habit, I run 4 or 5 pages through my 743.
If it hasn't been tried already, remove all toner cartridges and look for a build-up of toner inside. Also, try running the option to clean the ITB.
For the ongoing paper jamming trouble, I would, at this stage, reach out to Canon Customer Service. It could be that something is out of alignment and the rep should be able to tell based on some additional tests & checks.
