09-08-2019 02:31 PM
I bought a Canon ImageClass MF634cdw scanner/printer this year and it was working fine. I use the Canon MF Scan Utility and it will work when scanning single sided. However, if I click the box to scan both sides under Settings, then when I try to scan nothing happens. It "thinks" for a moment then nada. I've tried restarting and tried changing other settings to no avail.
Any tips?
Thanks.
09-09-2019 11:07 PM
I have the same problem. Any solutions?
09-11-2019 01:22 PM
Hi vicm333.
Which version of Windows or macOS are you using? Also, are you able to make a 2-sided copy directly from the feeder?
We look forward to your reply. If you need immediate assistance with this issue, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
09-11-2019 01:28 PM
I'm running Windows 10. I put the document in the feeder when i try to scan it - i've never tried to make a 2-sided "copy", so not sure about that.
09-12-2019 01:45 PM
I have 3 computers that use the scanner, all are running Windows 10. I can send,and pull 1 sided scans just fine. When I check the scan both sides button in the MF Scan Utility it never starts the scan, and eventually ends with an erroroccured, there is no error code.
