Canon MF4320D Not Printing, Scan Function Works – Driver Reinstallation Didn't Help (Windows 10 64-b
liluling
Hi everyone,
I'm encountering an issue with my Canon MF4320D printer. It used to work perfectly fine, but recently I noticed that while the scanning function still works, the printer is no longer printing.
I'm using Windows 10 (64-bit), and after some research, many suggest reinstalling the driver to fix this problem. I've tried deleting both the printer and the driver several times and reinstalled everything. However, the same issue persists. After reconnecting the printer, it behaves the same way.
When I attempt to print a test page, I notice that a print job briefly appears for 1–2 seconds and then disappears. No documents seem to be transmitted to the printer, and the printer remains inactive.(Print spooling is running )
I have also tested other Brother and Canon printers, and they work fine, so the issue seems to be isolated to this MF4320D.
Any advice or solutions would be greatly appreciated!
Thanks in advance.
1 REPLY 1
Ron
Moderator
Moderator
Hello liluling.  Welcome to The Canon Community, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market. The MF4320D isn't sold or supported by our team here at Canon USA.
If you live outside the United States, please CLICK HERE  and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
Friends and Family
