Canon MF Scan Utility and MF733cdw
mokotoy
Installed Canon MF Scan Utility on my MacBook Pro (OS X El Capitan)
It won't scan consistently. It would continuously throw an error:
Cannot communicate with the scanner.
The cable may be disconnected, or the scanner may be turned off.
Check the scanner status and try again.
Scanner driver will be terminated.
Error code: 600007
Error code: 600104
Cannot scan because of the following:
- Scanner is busy
- Error occurred in the scanner
- Scanner is in Sleep mode
Error code: 2100009
I would get varying errors. I ensure that the printer is awake and the scanner is ready.
I'm ablet to print ok, and scan via email ok. Something is preventing the connection between the utility and the printer.
please help!
1 REPLY 1
Patrice
Whiz
Hi mokotoy.
I will be glad to assist you.
Please delete the scanner from the MF Scan Utility Network Scanner window, and then re-register the scanner. To delete the scanner, please follow the steps below:
1. Display [Applications] in the operating system → select [Canon MF Scan Utility] in the [Canon MF Utilities] folder.
2. Select [Network Scanner Settings] from [Canon MF Scan Utility] in the menu bar.
3. Select the MF730 Series, and then click [-] at the bottom of the [Canon MF Scan Utility - Network Scanner] dialog box.
1. Click [+] at the bottom of the [Canon MF Scan Utility - Network Scanner] dialog box.
2. Register the scanner.
For a TCP/IP connection
Display the [IP] tab → select the IP address of the scanner → click [Add].
5. Start the MF Scan Utility.
6. Check that the registered scanner name is displayed in the main dialog box of [Canon MF Scan Utility].
If the scanner name is not displayed, reinstall the driver.
If you continue to experience an issue, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
