05-12-2020 01:08 PM
When I print on the MacOsx Catalina for network IPF8300S the document is spooling and then disappears the printer does not arrive. Help please
05-12-2020 03:40 PM
Hello.
The imagePROGRAF iPF8300S is not compatible with the Catalina (macOS v10.15) operating system.
To ensure proper uptime of your iPF8300S, please continue using the printer on a computer that is running macOS v10.14 and earlier or Windows 10 and earlier.
05-13-2020 08:43 AM
Hi! We ended support for the imagePROGRAF iPF8300S in August 2018, and that included ending software and driver development at that time. Operating systems that came out after that point will not officially be supported.
Hope this helps!
05-12-2020 03:40 PM
Hello.
05-13-2020 05:53 AM
05-13-2020 08:43 AM
Hope this helps!
10-13-2020 04:37 PM
Interesting that you ended support and won't release drivers for the current versions of macOS but you released a firmware update for this printer on 3/24/2020 and a firmware update tool for macOS on 1/7/2020.
I know it is an older printer but I'm not particularly excited to approve purchasing a new Canon large format printer simply because Canon decided they aren't willing to release drivers. And if we do get a new printer that just means we won't be buying Canon ink either.
