01-04-2024 03:02 PM
I have been trying to update the firmware on my Canon Color imageCLASS #MF753Cdw, but keep getting an error
I am using the MF753Cdw/ MF751Cdw Firmware Update Tool V03.04 [Windows], dated 09/01/2023 from the Canon website. The filename is "win-mf754-751-fw-v0304.exe". It won't update from the Printer's Firmware update menu option. I have tried running this from my desktop, from a laptop (connected via WiFi and Ethernet), and via a USB cable directly to the printer. The WiFi and Ethernet options cannot find the printer and I have to enter the IP address and the USB cable cannot find the printer, as well. The Support notice states "Vulnerabilities of network accessible products have been addressed." So, I thought it would be important to update my printer.
When I tried updating via a USB cable, I used the USB-A port on the back of the printer, as opposed to the USB-B port. Would this make a difference? (I don't have a USB-B cables anymore, which is why I used the USB-A port). Thanks for your help.
01-04-2024 05:36 PM
I tried contacting Canon Support via the email address listed on my Account for my printer, but the email bounced saying the email address was unmonitored. Alternately, it said to contact support through the Chat, which it said was available 9:00 am through 9:00 pm. But the Chat button, hasn't been available all day. My printer is still under warranty, so Canon, how do I get support other than calling?
01-06-2024 09:17 PM
I had same issue with a 652 that I just bought. Turns out, during set up, I entered 2023 as the current year (it is Jan 6, 2024 as I type this). Fixed the date to be 2024, and it updated with no problem.
01-06-2024 09:48 PM
Thanks, but I just checked the date and it is correct on the printer.
01-12-2024 10:44 PM
I had an issue with a printer and managed to get in touch with support, BUT, I was keen to speak to someone about a software/firmware issue, but instead was sent a replacement printer, with the exact same software-related issue - not ideal. I would like to know how best to contact Canon dev support, as my issue has now been confirmed by one of the scanner app software developers I've been interacting with
12-20-2024 11:09 AM
Hello,
To perform the firmware update via USB, you would need to connect the printer to your computer with a standard A to B USB cable. To contact support for the MF753Cdw, you can call support over the phone at 1-800-652-2666. Our agents would be happy to check what might be causing the firmware update issue and walk you through the process.
