Cannot scan, receiving message cannot start scanner driver while it is use by another application
Dan59
Trying to scan with Image Class MF733cdw and a iMAC on catalina. Getting the message "cannot start scanner driver while it is in use by another application or user " I'm not using any other application.
Any suggestion?
Hi Dan59.
Please let us know if you are still having issues, after installing the updated drivers and software.
6 REPLIES 6
Before we go further, can you confirm you are using the latest Catalina specific drivers released 10/4 (this month)?
MF733CDw Support
Thanks
Dan59
No, I’m not. Was not aware of new drivers. I will download them right away.
Hi Dan59.
Yes, indeed. problem fixed.
Went crazy trying to fix this problem before I saw your message on the new drivers...worked great!!!
Thanks!!!
I have a Canon MF440 Series (specifically, the MF445dw), which uses the Canon MF Scan Utility.  I get the same message as others on this thread:  "The scanner is not available while in use by another application or user."  If I close out the Canon MF Scan Utility (and cancel the scan request on the printer), I am able to start over with a scan request from the printer and everything works fine for the second scan.  However, the problem repeats itself for the third scan, i.e., Canon MF Scan Utiliity remains open in the background following the second scan, so the program blocks the third scan with the same error message as above.
Two important nuances here:
- if I login as an administrator and install the scanner driver there, I do not have the above problem.  The scan utility closes after each scan and so does not block the subsequent scan.  However, when I login again on my user account, the scanning problem returns.
- I have a second Mac in the house that does not have the above problem even when logged in as a user.  Both Macs are on the Big Sur operating system.  I checked the permissions on the app on both computers, and they are set up the same.
I tried uninstalling the scanner driver and updated to the January 2021 scanner driver (1.10.6), but it does not help.
For whatever reason, Canon MF Scan Utility is remaining open in the background on just one computer and only on the user login of that computer.  Is there a solution to this problem?
Thank you.
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
