02-10-2025 06:59 PM
I am able to print from my computer to the printer but in trying to scan a document, I get an error message on my screen that says,
"Cannot communicate with the scanner. The cable may be disconnected, or the scanner may be turned off. Check the scanner status and try again.
Scanner driver will be terminated"
The computer and printer are both connected via wi-fi so there's no cable used.
Can anyone help?
Thanks
02-13-2025 03:41 AM
This is what solved my scanner connection issues for me on my Canon MF752Cdw.
After executing these steps, the scanner should have a connection again.
A big shoutout to Dale1973 who came up with this solution.
02-13-2025 04:14 PM
Hello.
So I encountered this error today with an imageCLASS MF656CDW multi function unit. After some crazy stumbling around I found this combination to work on a Windows 11 24H2 PC with all current windows updates:
1. Install the Master Driver utility package (mastersetupv110) from the canon website
2. After this is installed, run the scanner utility package if you want to scan from your machine (winmfscanutilityv12102). If not skip this step.
3. Open device manager -> imaging devices -> canonMFmodel. Right-click and uninstall (but do not remove the driver package).
4. Download and run the [Windows 64bit] MF656Cdw/ MF654Cdw/ MF653Cdw/ MF652Cw MFDrivers (Generic Plus UFR II / Generic FAX / ScanGear) installer (MF650CMFDriverV720W64) package from the canon website
5. Follow all prompts and install all components that you plan on using (i unchecked faxing and the ability to install the service).
6. Once this finishes, go back to device manager -> imaging devices -> CanonMF model
7. Right-click and "Update Driver" -> Browse my computer for drivers -> Let me pick from a list of available drivers on my computer
8. For the 656CDW, you will see 2 drivers. One with a 2023 date and one with a 2021 date. Select the 2021 driver and click next to install/use it.
Once this is done, scanning was working again. Whether its directly from the printer or using the app or hard wired or setup wirelessly. Scanning was working great again. Oddly enough it looks like the last driver update was yesterday, but this driver doesn't work. Hopefully this helps someone save several hours, as it took me a while to get this to work 😞
This combination worked for me without any issues. Hopefully it works for you.
