Cannot scan after changing routers (MF229)
vknowles
Everything was working well, then over the weekend I changed my router. The printer's IP address changed.
I can still print, didn't have to reset anything to print.
But I cannot scan. The MF Toolbox says "A supported scanner is not installed." The MF Network Scan Utility does not show a scanner.
I read in an old post that a similar problem (2013) was solved by reinstalling the drivers. Is that really necessary?
Thanks!
vknowles
I ended up downloading and installing new drivers. I also had to install the Network Scan Patch. Now everything is working.
1 REPLY 1
vknowles
