12-19-2021 06:26 PM
ImageClass MF 634Cdw
USB printing setup, no network or WiFi printing.
Replacement Toner cartridges are all Genuine Canon brand.
iMac running macOS Big Sur 11.6.2
Canon driver D/L & install for Big Sur 10-26-21:
MF Printer Driver & Utilities for Macintosh V10.11.8 [OS X 10.11.6 - macOS 12]
Fax Driver & Utilities for Macintosh V4.15.11 [OS X 10.11.6 - macOS 12]
Scanner Driver & Utilities for Macintosh V2.15.9 [OS X 10.11.6 - macOS 12]
7 months ago, I replaced Black w/o issue.
Today I replaced all 3 colors & now cannot print.
Canon now shows Black 90% & 3 colors 100%
Cannot print a test page or any document!
“Error While Printing” pop up immediately after I select print.
Turning Off/On Canon, no help
Restarting computer, no help
Did I waste hundreds of $ buying 3 genuine Canon toner cartridges?
12-22-2021 08:56 PM
I ck to see if my drivers were still latest since D/L 10-26-21 & they are same exact version #s!
Previous drivers said thru macOS 12 & now says thru macOS 12.0.1
Same exact file sizes
So, I will not D/L the same drivers!
I have 5 drivers in System Preferences
4 under Printers & 1 under Faxes
I deleted Canon_MF632C_34C_UFR-II under printers (highlight & click
“-“ sign)
I added it back by clicking “+” sign & got new window with 2 choices & one choice was Canon_MF632C_34C_UFR-II
Try to print
It worked!
Zero help from Canon.
HTH someone else.
12-20-2021 10:25 AM - edited 12-20-2021 10:25 AM
Are you sure you removed all of the shipping tapes from the new toners. Sometimes they have tape to secure for packaging/shipping.
Power off the printer. Remove and reseat each toner in the carrier / tray.
Retest.
The printer has a 3 yr warranty, next step, call Canon.
12-20-2021 01:52 PM
I had already tried remove/reseat each cartridge, no help.
I just triple checked now & no packing tape.
I’m past 3 year warranty.
I doubt the printer just happened to break after changing cartridges.
But, IDK what the issue is. I did not move the printer or disturb the USB connection.
12-22-2021 08:56 PM
“-“ sign)
Try to print
It worked!
HTH someone else.
