Cannot install Canon GX7021 on Linux (Fedora 36)
canondale
The install procedure cannot find the Canon GX7021.  I followed the procedure described in the "IJ Printer Driver for Linux (Operation guide)".
The printer is definitely on the network and turned on.  The command "lpinfo -v" finds it:
network dnssd://Canon-GX7021._ipp._tcp.local/?uuid=00000000-0000-1000-8000-0018a8016a14
network ipps://Canon-GX7021._ipps._tcp.local/
But the installation program does not find it.  Specifically, /usr/lib/cups/backend/cnijbe2 and /usr/lib64/cups/backend/cnijbe2 do not produce any output.
1 REPLY 1
yourcableguy
I'm having the same issue.  My printer is connected to the same network and subnet as my desktop.  I can ping the printer no problem but the script can't find my printer on Fedora.  I had no issues installing it on my popOS laptop with the  Debian installer.
I went through the system settings to install the printer, but since i couldn't use that install script it may have something to with the scangear program can't see the scanner too.
Friends and Family
