Can't download firmware on Mac or PC for imageClass LBP6230dw printer
jeffmr4
Just as the title says I can't download firmware on Mac or PC for imageClass LBP6230dw printer.  Whenever I get to the page where it asks for a serial number I enter it and it says that is incorrect or not for the correct device.  I've tried a number of other numbers on boxes and warranty, etc but none work.
I'm sure the one I am entering is correct.  It is on the box, back and bottom of the printer.
Does anyone know how I can download the firmware?
Thanks.
jeffmr4
After calling Canon Technical Support, they gave me the correct serial number for the device.  They said that depending on when the printer was manufactured that some of the information in their database hadn't been updated.
So, I downloaded the firmware.
Thank you for your response.
2 REPLIES 2
Your serial number should be a combination of letters and numbers. When entering for downloads, you enter letters and numbers only, no spaces of hyphens.
If you continue to be unsuccessful, I'd use the chat feature in the support portal.  I've had good luck with it.
jeffmr4
