CHANGE DEFAULT COPY SETTINGS ON MFU242DW PRINTER
1775
How do I change the default copy type to TEXT/PHOTO so that this is how the copy will be made when the machine comes on to make a copy?  Right now it has to be set to this each time from TEXT/PHOTO  (HIGH SPEED)
Hector
Hello 1775,
You can change the default copy settings for the MF242dw using the steps in the link found HERE. It will show you which default settings you can change and the steps.
1 REPLY 1
Hector
Hello 1775,
