Airprint LBP162dw Duplex issues
Trophimus
My LBP162dw prints duplex fine from PC.  However, using airprint from IPAD Air 2 tablet (with duplex turned on in IPAD and IPP set to ON in Remote UI settings, and 2 sided printing set to ON) the second page comes out on a separate page upside down.  How to fix this?
2 REPLIES 2
Darius
Whiz
Hi Trophimus.
Was the printing being done from the Canon PRINT Business app?  The Canon PRINT Business app maintains its own print settings (including two-sided printing).  If this problem is occurring in a different app, double-check the settings in the Print window.  If possible, try printing the document or image from a different app.
The print button is part of the IPAD operating system and is not a separate APP.  It does have the option to set two sided printing to on (slide button).  I also tried using google cloud print through my android phone and the same thing happened.  I talked with a Canon representative and he thinks it has something to do with Apple's not sending the correct instruction/data from the IPAD.  I don't know about Google print.  So, I guess I'll just have to use the PC (which does work) when I want to do duplex, two sided printing, unless someone has a solution.
