- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
10-25-2015 07:07 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-01-2015 06:47 PM
Hi, I've resolved donwloading the windows 7 64bit version and then I've selected the downloaded file ( cp800w764.exe ) and selected "Troubleshoot compatibility" and then I've selected "Troubleshoot program". The system then ask with a series of checkbox "What problem do you notice?" and I've selected the first option "The program worked in earlier version of Windows but won't install or run now".
Then press next
Then I've selected Windows 7 from the list
Then pressed next
Then on following windows I've press "Test the program..." button, the installation started and I was able to do the full installation of the driver. Don't know if it needed or not but before doing this procedure I had already connected the CP800 to an usb port and switch it on.
After the installation of the windows 7 64bit driver under "Devices and printers" I see it as a normal printer and was able to print normally on it.
hope this help
best regards
S
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-25-2015 04:40 PM
I don't believe it's compatible.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-01-2015 06:47 PM
Then press next
Then pressed next
hope this help
best regards
S
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-08-2017 09:03 PM
That worked!!! Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-13-2017 09:36 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-18-2018 10:24 PM
Right click on the install exe file and you will see the drop down menu with the "Troubleshoot compatibility" listed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-20-2021 06:00 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-11-2021 05:10 AM
You're **bleep**ing genius, Man!
Thank you!
I've found your post for a miracle...Canon must be ashamed about this. I think it would need some second to make the driver for win 10 and put in the list of drivers...but for sure, business is business, so better try to sell new hardware than make useful the older...put your selphy cp 800 in the trash while we will make spots about how to save the planet and the environment...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-11-2022 04:23 PM
You made my life ! oh God! I was so desperate , thinking to buy a newer version of this printer!
Thank you so much!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-29-2024 08:59 AM
Absolutely perfect! Thanks a lot for this I've just installed the driver ( cp800w764.exe ) found easily with Google. OK had to do a few more steps than explained but they were obvious can't remember what they were. So it still works on Windows 10 August 2024.
Thanks a lot!
