11-11-2022
06:34 PM
08:55 AM
I am trying to print from my computer using USB. I'm running windows 10 home edition. The printer will only give me the following three options for paper size: 1) Japanese Postcard, 2) Credit Card, and 3) Metric Photo L. It will print 4x6 from a the card reader but will not from the computer. It is using a Microsoft IPP Class Driver.
Any help would be great.
Thanks
12-01-2022 07:20 PM
Under advanced options in the printing settings of the "driver", I had to turn on borderless printing and set the scaling to Fit.
11-24-2022 04:51 AM
I believe that Japanese Postcard size is 4x6.
11-24-2022 01:50 PM
It looks like it is just a little smaller but I will give it a try. Thanks. It still doesn't show other sizes.
12-01-2022 07:20 PM
08-23-2023 06:26 PM
I have turned on borderless printing and have scaling set to Fit and it's still not working, any other ideas to try?
05-22-2024 04:34 AM
I still have the same problem.Actually, that japanese paper si not the same like 4x6, the print is a little bit smaller on the photopaper. When I print form the PC with fit option, the print is ok, is made good, But I use dslrbooth software for a photobooth and the print is in japanese size...
05-22-2024 04:34 AM
Hi, you find a solution?
05-22-2024 04:38 AM
is not, is a little bit smaller
