nodal point for Canon 24-70mm F2.8 II
limvo05
Rising Star
Hi All,
Instead of buying all kind of gears for pano photography, I was wondering if there's a published Nodal Point chart for all Canon EF lenses?
If there isn't one, what pano gear would you recommend?
Thank you,
LV
12 REPLIES 12
Yes there is a limit in PS to file size. It has to do with saving it. This also depends on which version of PS you have and what OS yu are runnung.
@limvo05 wrote:
Thank you for responding to my question.
In my recent outing, I took a 10 shot pano of the Grand Teton mountain range, final product is pretty impressive, however, I am running into one technical issue. When I try to save the photo, PS is telling me that the file is bigger than 4GB, or something along that line. Wondering anyone here ran into this same issue, and how did you fix it?
Thanks!
You have asked that question before.  The answer has not changed.  It is not a PS/LR error.   You are running up against the max file size limit of Windows.
"Fooling computers since 1972."
"You are running up against the max file size limit of Windows."
Yes, sorta, sometime ago Adobe came out with a PSB (not PSD) file extension. It allows for a much larger file. I am still on CS6 so I have not and do not have a reason to investigate it.  You may want to.
