04-27-2019 09:16 PM
I noticed recently really loud IS in my 24-105, loud enough in fact to be picked up by the on-camera microphone I used.
Is this normal, or should I seek out repair?
04-28-2019 01:29 AM - edited 04-28-2019 01:42 AM
Yes, it is normal. The EF 24-105 is known for its noisy IS which is easily picked up in videos using a built-in microphone.
Here is a video showing how noisy it is: Canon 5d MKII Video Image Stabilization IS Lens Test with 24-105
04-27-2019 09:51 PM
Since I can't hear the noise, who can say? If you think it is out of the ordinary you better have it looked at. You'll always worry if you don't. Otherwise forget it and just use it.
04-28-2019 09:43 AM
04-28-2019 08:24 AM
@San2C wrote:I noticed recently really loud IS in my 24-105, loud enough in fact to be picked up by the on-camera microphone I used.
It is probably normal. The lens is not very good for video because of the noises it makes. If you are on a tripod, then you can turn off the IS completely. That sill leaves the noise from the actual AF motors, and the even noisier aperture.
The simple cure is to use an external microphone that is far enough from the lens to not pick up any of its’ noises. Even a directional microphone mounted on the hot shoe should be sufficient to minimize the noise.
