09-27-2018 06:35 AM
My father has a canon scanner Lide 110 that uses MP Navigator X.
That software does not longer work with macOS Mojave, it wont even start. That sucks.
Does anyone know of a good scanning software that works with Lide 110?
Preferably software that detects multiple photos and saves them individually as jpegs.
thanks.
02-09-2019 09:40 PM
Here's something you can try..
Keep your MP Navigator 3.1 installed (for now)
Install the MP Navigator 4 from the link canon asia link above
go to Applications/Canon Utilities
Right click on MP Navigator 4 and select "Show Package Contents"
Navigate to Contents > Plugins > Database
You will see a bunch of .plist files -- these correspond to the scanners that the asia 4.0 version of the app supports
Right click on MP Navigator 3.1 and select "Show Package Contents"
You will see a bunch of .plist files -- these correspond to the scanners that the us 3.1 version of the app supports
Copy the files from the 3.1 database folder to the 4.0 database folder
Now when you start MP Naviagor 4 it will launch correctly and find your scanner.
I have not analyzed the contents of these plist files so I'm not 100% sure if this will work, but the contents of the files in the 3.1 version look pretty similar to the ones provided in the 4.0 version.
12-20-2018 07:23 AM
I have spent an enormous amount of time scouring sites and comment boards to find a solution to this problem with no success. I have called Canon and they refuse to even provide a human to discuss support. They have simply left their customers out in the cold. Seriously......UPDATE YOUR **bleep** PRODUCTS. At this time I have a large brick sitting on my desk with absolutely no viable solution. The least they couldve done is warn their customers. So, im forced to trash the unit and purchase a new one from a more reliable and dependable manufactuer. Thanks for nothing Canon.
10-24-2018 12:09 PM
10-24-2018 06:30 PM
No pop up on left side of window using MG8220.
11-29-2018 12:04 PM - edited 11-29-2018 12:11 PM
The above answer, using System Preferences, click on "Printers and Scanners", worked for my MX320. It's too bad that Canon doesn't support their printers for very long, but at least using the Apple utilities I don't have to totally junk it yet. I had tried newer versions of MP Navigator, but they would not support my older model.
12-12-2018 04:44 PM
10-19-2018 06:43 PM
10-19-2018 06:50 PM
I purchased Vuescan which appears to work well with Mojave. With Canon, it is always a day late and a dollar short.
10-25-2018 01:17 PM
11-16-2018 01:42 PM - edited 11-16-2018 02:17 PM
I have MP Navigator 5.1 installed on my Macbook Pro 2017. I just upgraded to Mojave. The application no longer will appear on my desktop when I try to start it. I don't believe there is a new version of the application and I have verfified that all drivers have been installed. Is there a way I can get the application to work?
I have Pixma MP432 printer
I tried IJ Scan Utility Lite and it worked. I liked MP Navigator better because of the interface. Are there other options that have a better interface?
Thank you,
Teri
11-21-2018 02:04 PM
teribear515,
The MX432 is not compatible with the Mojave operating system. For details about what versions of Mac OSX the printer can be used with, visit the following link:
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
