scanner lide 110 errors 5, 202, 52
jakehues
hi
this is a new scanner just installed with win 7.
it did work one time. then not:  errors 5, 202, 52.
now after reinstalling the driver and reseating the cable, the error code is 5, 155, 75.
jq
3 REPLIES 3
jakehues
after no responses, maybe....
hi
this is a new scanner just installed with win 7, 32 bit.
jq
Jason
Whiz
Hi jakehues!
Welcome to the Canon Forums and thanks for your inquiry.  We do hope someone in the community is able to help!  We do want to mention that the forums aren't meant for immediate assistance, but are designed to allow the community to help each other with issues encountered or tips they'd like to share along the way.
 If this is a time-sensitive matter, our US-based technical support team is a much more efficient way to get help! They're ready to help 24/7 via Email at http://bit.ly/EmailCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
We hope this helps!
Hi jakehues,
The 5,155,75 error is a generic communications error and unforutnately does not pinpoint the cause.  Please make sure that the USB cable that you are using is 6 feet long or shorter.  Also, please make sure that the USB cable is connected directly from the CanoScan LiDE 110 to your computer and is not connected to a USB hub or some other device.  Please disconnect all other USB devices connected to the computer and then attempt to scan.  Are you able to scan?
If not, please try temporarily disabling security software and then attempt to scan, as firewalls and anit virus have been known to cause these type of errors as well.
If you continue to have difficulties, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
