Where'd my edits go in Lightroom???
ScottyP
I bought a new computer. I store all my raw images on a portable hard drive.
I was using LR4 on the old computer, which I had upgraded online from the box-and-disk of LR3.
I was in a hurry and did not know my old adobe account name or any of that, so I just loaded LR3 from the disk onto the new computer, then I bought the upgrade for LR5 since it was cheaper as an upgrade.
Now all my edits are gone.
Are the sidecar files on my old hard drive? If so, is it possible to have them live on the portable hard drive? Is it advisable?
Scott
4 REPLIES 4
Skirball
They're in your LR4 catalog, wherever you backed it up (most likely your old comp).  You'll have to import the old catalog into LR5 on your new comp.
ebiggs1
The old computer is still viable?  Lightroom does not really like it when you do things outside of it's own software.
You may need to install LR3 and than upgrade it to LR4 and finally to LR5 on the new computer.
I would also copy each catalog (backups) to the new version(s) and computer..  Maybe you only need LR4's stuff.  But since LR3 was your only full program, I still think I would go through the process.
Of course you changed computers but it is always best to use LR to do any moves or copying and not any file manager outside LR.
EOS 1DX and many lenses.
Actually, you don't have to re-install and upgrade. You can just install the latest version of Lightroom. Then open your old catalog using the new version. Lightroom will ask if you want to upgrade the catalog. Choose YES, and it will do the rest. Also, when upgrading, it will make duplicate the old catalog so in any case if the upgrade is failed, you still have your old untouch catalog. There is no point of installing many version.
Back to ScottyP, all lightroom edits are stored in its catalog. So you would have to copy the catalog on your old computer to the new one and open it with Lightroom 5. Then, it will upgrade your catalog to LR5 and you can open it.
Since you store all your photos on an external drive, you may need to change the drive letter of the drive on the new computer to match to old one; otherwise, LR may say that your photos are missing. For example, when you plug in your external HDD into the old computer, the computer assigned it drive letter D. Then make sure, on the new computer, when you plug in the same drive, it have to give you to same drive letter D.
Good luck.
Weekend Travelers Blog | Eastern Sierra Fall Color Guide
I am pretty sure you can use the File -> Open Catalog command and select the new catalog from the connected drive. You don't need to rename it.
Friends and Family
