WHAT CAMERA SHOULD I GET?!
toweltrick
Ahhh, back to beating that dead horse with such a question. But I'm so unsure on what DSLR to get! I just need some secondary opinions because maybe someone else will point something out that I'm overlooking.
Currently I have a Olympus OM-D E-M10 mark II and a film camera, the Olympus OM2n. Recently I tried using my E-M10 to photograph a sports event (thankfully I was just doing it for fun and not professionally) and it failed MISERABLY! The camera's auto focus cannot find anything fast enough and when it does.... its the background and not the player you are trying to focus on. There is no manual override on the lenses I have so I couldn't intervene and fix this myself. I was looking at lenses to get that I could focus manually with but micro four thirds (or Olympus lens mount) lenses are so expensive I came to the decision to just get a different camera.
Right now I am pretty set on the Canon EOS Rebel T7i. Is there anything I'm overlooking? Any other camera someone would recommend near that price range? The T7i looks to be a pretty amazing camera.
Thanks for any help.
48 REPLIES 48
Tronhard,
I have a T5, and love to use it.  I love it so much that I started a "Love my Rebel" thread in the "Share Your Photos" forum.
[EDIT]. Great shots, BYW.  But, all of them are stills, not action shots.  All of them were shot with relatively small lenses, compared to the lenses popular with sports photography.
I'm not saying a Rebel is not capable of action shots, but the OP is an experienced photographer.  Given the choice between a n entry level camera or an enthusiast grade camera, I think the latter is the most sensible choice.
@Waddizzle wrote:
Tronhard,
I think recommending a Rebel to an experienced photographer is bad advice.  The camera body will be outgrown within a few months, or a few thousand shots, whichever comes first.
I think a T7i is not good advice compared to recommending a 77D, which is well within the stated budget, as is an 80D at the Canon Refurbished Store, where I have bought two of them with the 18-55mm STM lens for WELL under the budget.
When the 77D first came out, we were at a loss to understand its intended role in the product line. We discussed it for a while; and as I recall, we finally agreed that for all practical purposes the 77D is a Rebel. What has changed?
Bob
@RobertTheFat wrote:
@Waddizzle wrote:
Tronhard,
Nothing changed the 77D is the Rebel T7s renumbered.
The only thing I see lacking on the T7i is micro focus adjustment, and gong to the 77D doesn't give that to you.
So either stick with the T7i or make the jump to the 80D.
@Waddizzle wrote:
Tronhard,
No AFMA in a 77D?  It does add the top panel LCD, though.  I would have assumed the T7i included AFMA.  So, in other words, he 77D is more Rebel [T7s] than a true ##D series body.  Why would Canon do that?
@Waddizzle wrote:
Tronhard,
hHi Waddizzle
Thanks for your response.
So I need to clarify one thing.  Is the question about getting the body only, or a body and lenses?
The problem is the budget....  If all what is requried is just a new body then I willl be rigtht with you, in fact I would be keen to get the 80D if I could find a decent second-hand one because of the better tracking, it works well with the extender and long telephoto and you can put a battery grip on it to add capacity and balance a big lens.  But if  he wants lenses then I would normally put more emphasis on the glass.
cheers, TREVOR
@Tronhard wrote:
@Waddizzle wrote:
hHi Waddizzle
I have bought two of these.  They are a fantastic value.
https://shop.usa.canon.com/shop/en/catalog/eos-80d-ef-s-18-55mm-f-3-5-5-6-is-stm-kit-refurbished
GUYS! I got the T7i with the 18-135 lens!
I see what you guys are talking about and, as I said in my last post, I do not do sports photography. I may have lead some people on with that since that's what I mentioned in the original post but sports is not what I do. I only did sports that day for fun and it made me realize a major weak spot in that olypmus camera. That, compiled with the bad taste of how expensive lenses are for it, made me want to switch from it. I picked up the T7i on Friday and did some sunset shots with it and then today did a couple car shots. So nothing to put this camera through its paces or test its limitations. But I am very happy with it.
This will start the beginning of photography as a side job for me. I am looking to use this camera for portraits more than anything else. Attached are two of the first images I have taken with the camera.Cookie-4.JPGSunset-1.JPG
Nice. I'm always up for a good sunset shot.  Smiley Happy
Bob
That sunset is gorgeous.
 The Rebel T7i is a very capable camera no matter what some of the nay sayers tell you.  Don't believe them, it will do sports if you so desire.
I know you will enjoy it for a long time to come.  Smiley Happy
EOS 1DX and many lenses.
russ49
If you want to experiment with your Olympus on sports, I've noticed as well as read that a mirrorless camera will focus using the chosen aperture and not the widest aperture that  the lens is capable of. If you use the widest apperture that the lens is capable of your autofocus will work at its max because of more light being let into the camera. When using an OVF (Optical View Finder in a DSLR like the T7i) you are always using the lens at it's max apperture for the focal length chosen. See if that helps. For example I have a 18-150mm lens the max apperture at 18mm is f3.5 and at 150mm it is f6.3 so using the lens at 18mm and f3.5 you will get better autofocus then at 150mm and f6.3 because of the great differnce in light transmission. Using the lens at 18mm is not at all ideal for sports but is just to emphasize what I'm saying. If you have this lens set to 18mm and F5.0 then a mirrorless camera will use f5.0 to try to focus but a DSLR (T7i) using the OVF will use f3.5 to focus even though your actual apperture is set to f5.0. Using the DSLR in "live view" with the above scenario it will use f50 apperture to gain focus just like the mirrorless because you are using the DSLR in a mirrorless setting.
Friends and Family
