Re: My images seem like they could be sharper. I use all L lenses, any suggestions?
BDeKid
I allways  shot   with  Picture Style  Neutral  or SuperFlat  , which cause the Pic  to  be a little  bit  unsharp.   I then  use  DPP  and  sharpen the Images ( RAW)
But mostley  it  is an god  Idea  to  send your  Equipment  ( Lens and  Body)  to  Canon Service  so  that the y  can  calibrate  the SetUp   I  do that  with   every new  Lens  and Body SetUp
Greets
B.DeKid
2 REPLIES 2
iND
As you analyze your 'sharpness' issues
make sure you consider:
camera shake
slow shutter speeds
focusing issues
aperture issues
before  you send in your lens
try tripod mounted shots at 1/100-1/250 with apertures of 4.0 or 5.6 (sweet spot for a lot of lenses)
also try single point focus as a trial especially at apertures 2.0 and below
camera shake
slow shutter speeds
focusing issues
aperture issues
^Definitely do this first.
OOF, shutter speeds too slow, IS turned on while on tripod, MA may be needed. There are a lot of things to check to make sure it's not user error before sending it in. Otherwise you get a lens back from Canon and have the same issues.
Holiday
