Just a thought…. Photo Vs Mini Movie Clip
Afzal_BG_BR_UK
Enthusiast
Now that DSLR/Mirrorless cameras have ‘Movie’ capabilities, why bother actually taking a photograph? Simply create ‘Clips’ to ensure you capture the “right” moment then edit the actual ‘frame’ that represents what you intended to capture!
Am I missing something?!?
I myself am a bit ‘old-school’, I would rather capture a photograph as SooC as possible, then simply ‘crop’ (where/when) necessary ready for print/distribution.
Cameras:- 7Dii & (x2 40D)
EF:- 100mm f/2.8 macro, 50mm f/1.8, 24mm f/2.8
EF-s:- 55-250mm, 10-22mm, 18-55mm
Flashes:- x4 580exii, MT-24ex, Godox AD300Pro
Triggers:- x5 PW TT5s & x2 PW TT1s & x3 Godox X-Pro
kvbarkley
Yes you are missing something.
Check the resolution of the movie vs the still file.
My TG-5 has a mode where it continually takes images, and as soon as I press the shutter saves the 5 *before* the shutter press and 5 after.
2 REPLIES 2
kvbarkley
Aha. Much appreciated!
So, the created movie file resolution is inferior on a frame-by-frame basis compared to a still photograph.
[I mistakenly thought that every movie frame would be the same resolution as any captured still photo.]
Phew:- thankfully, I still have a reason and justification to take photos. Long-live photography!
