GP-E2 GPS receiver stopped working
AheadAir
Worked fine previously. Now unit does not stay on. When switched on, power light gives one long flash, gps light gives 3 short flashes, then nothing. No lights, camera doesn't see unit in hot shoe and computer doesn't see unit on USB.
7 REPLIES 7
Waddizzle
Sounds like the flashes might be an error code.  What does the User Manual say about it?  Is it able to receive a signal?
I don't think the flashes are an error code. I seem to recall that it has always flashed like that at power up. The battery light should flash slowly and the gps light should flash every 3 seconds when it has a lock. There is no reference in the manual to any POST flashing or anything other than normal operation.
@AheadAir wrote:
I don't think the flashes are an error code..
It might mean low battery.
Mine is doing this with a full battery.
It's been almost a year and a half. Did you ever contact Canon?
Peter4833
@AheadAir wrote:
Worked fine previously. Now unit does not stay on. When switched on, power light gives one long flash, gps light gives 3 short flashes, then nothing. No lights, camera doesn't see unit in hot shoe and computer doesn't see unit on USB. mymilestonecard
I have the same problem with facing same issue but no response from anyone and couldn't find this topic troubleshooting in search engine.
Call 1-800-OK-CANON
Friends and Family
