Canoscan LIDE 210 light not working in Windows 10
Ascidian99
Canoscan Lide 210 works fine on WIndows 8, but when I connect to a Windows 10 PC it does everything except trigger the light when scanning so I end up with an all black print. (putting it back on W8 all good again).  Does this for PDF, photo's etc
Have tried updating all drivers & checks using MP Navigator EX say working normally.
Any suggestions please?
3 REPLIES 3
Ascidian99
looks like it needs to be connected through a powered hub.  Presumably the USB ports on the PC don't provide sufficient juice.
Due to the absence of a power adapter with this device, that could work.
It might be helpful to others if you post your findings.
Ok - here are the results of a bit more checking - but the short answer is "USB cable length".
After the initial problem of the light not coming on resulting in all black scans  the first attempt to fix was via a powered hub, which worked for a day.
But then all sorts of inconsistent problems happened; all white scans, all yellow image & text, scanning locked up part way,  error codes 5,202,52 or 3,202,19.
All this happened whilst the scanner was attached via it's own cable plus an extension.  I could use that config. on the old PC and since all I did was to move the extension cable between the two PC's the problem was not immediately apparent.  But after getting such inconsistencies in results I physically moved  the scanner to the new PC and cabled it directly without the extension cable or via a hub and that worked consistently.
Presumably the extra length caused voltage drop and messed up signal timing hence the variation in results.
HTH.
