Canon Pixma E460 Printer Unique problem
JamieBanks
I have a canon pixma e460 printer in my house then i bought a new e460 for my parents’ house which I want to use. so now I have two exact printers. since I have installed the drivers of the e460 on my macbook for the first printer months ago in my house using my home wireless LAN router (the set up was pretty simple because there I was guided through my Canon driver while setting the printer for the first time on my macbook air),
Hence i don't need to install it again during my set up for my second e460. how do i connect the new e460 printer to my parents’ home’s wireless LAN. I have been wrecking my brain and searching online for hours on how to go about it. I still could not get it connected to my wireless LAN (home wifi).
Tried changing the network configuration via the canon menu software on my macbook, and I have successfully connect it to my parents’ home wifi, however when I tried printing, it is still not connected. So i pressed the wifi button on the printer until the alarm light blink 3 times. AfterI did that, I can no longer change anything on my printer network configuration. The SSID is now changed from my home wifi name to B7B6DD-E460series. Please please help. Appreciate it. Thanks so much
1 REPLY 1
Waddizzle
You should probably delete the printer and start over from scratch.  I suspect that the final solution is going to involve having two different printer configurations.  Does your MAC allow you to connect to different networks, and reconfigure itself for each one?
For example, most windows PCs allow you to setup a "Home" network configuration, and an "Office" network configuration, by default.  It is possible to add additional named network configurations.  Your "Home" configuration would use one printer, while your "Parents" confiuration would use the other.
Why two printer installations?  Because they are physically two different devices with different MAC addresses.
