04-07-2016 10:48 AM
Hello.
I have a Canon CanoScan LiDE 210 and i'd like to use it with 2 computers. Now i can only use it when the 1st computer is powered (scanner connected via usb cable, not ethernet port ) on and the scanner is shared from it. The problem is the 2nd computer can only use the scanner, when the first is turned on.
What would be the solution? Maybe this cable: CCP-USB22-AMAF-3 (1 female to 2 male usb cable) can be the solution?
