CanoScan not working
Phandi
I am using Lide 110 scanner connected a Mac laptop with Hyper Drive connector. Scanner reported an error. see below.
I have done the above procedure several times, but no success.
Can you please assist.
4 REPLIES 4
I suspect the issue is related to the adapter.
You are trying to use the scanner with an unsupported OS.
You'll have to provide more information about your environment.
Thank you for your advise.
I have also tried the scanner on Dell Laptop, but no difference.
I'm using macOS Big Sur ver 11.1
So the scanner is not working when connected to either computer (MAC or PC).  That indicates a problem with the scanner or cable.
Thanks for your insights, Shadowsports. Much appreciated.
Friends and Family
