02-05-2021 06:48 AM
I am using Lide 110 scanner connected a Mac laptop with Hyper Drive connector. Scanner reported an error. see below.
I have done the above procedure several times, but no success.
Can you please assist.
02-05-2021 09:25 AM
I suspect the issue is related to the adapter.
You are trying to use the scanner with an unsupported OS.
You'll have to provide more information about your environment.
02-05-2021 09:39 AM
Thank you for your advise.
I have also tried the scanner on Dell Laptop, but no difference.
I'm using macOS Big Sur ver 11.1
02-06-2021 09:05 AM
So the scanner is not working when connected to either computer (MAC or PC). That indicates a problem with the scanner or cable.
02-06-2021 11:26 AM
Thanks for your insights, Shadowsports. Much appreciated.
