03-18-2026
03:11 PM
03:19 PM
Tiffany
Does anyone here have the Canon RF 85mm f/1.2 lens? If so, what make/brand kind of UV filter do you use?
Thank you,
Steve Raub
03-18-2026 04:00 PM
Don't waste money on a UV filter. If instead you want some additional protection, look at a clear filter. However, keep this in mind: you'll be putting another piece of glass in front of the lens' excellent optical elements. So be sure to get a good quality filter.
Personally I use B+W filters to include their "007 Clear MRC Nano Master" product. I also use the same brand for Circular Polarizer and Neutral Density filters.
Another option is to use a lens hood which can add protection to the front element instead of using a filter. Though my personal feeling is it's better to have damaged the filter than the front element.
Finally, one other thing to look at when buying filters. Be sure that the material of the filter's ring is different than the material used at the front on the lens. This helps reduce binding. Though you still need to be careful to not over tighten. The B+W filters I have use a different material than both of my Canon's lenses filter threads.
03-18-2026 05:22 PM - edited 03-18-2026 05:23 PM
Modern mirrorless camera’s don’t need UV filters. They’re essentially a throwback to film cameras. Adding a clear filter can offer a limited amount of protection along with a lens hood as previously mentioned by rs-eos.
Personally I prefer Maven brand filters. They are tier one filters (high quality) like B+W, but are magnetic mounts. Screw on an adapter ring, add a clear “Splash Guard” filter and you’re good to go. The filter can then easily be added and removed. They also make Splash Guard’s that screw onto your lens and have the magnetic adapter built in as well. It’s what I use on my lenses.
A Linear Polarizer (for mirrorless cameras), or a Circular Polarizer (for DLSR’s), via their magnetic mount system can then also be easily added and removed along with any of their other filters. Magnetically mounted filters help save time between shots and avoid cross threading as well as fumbling around trying to screw on a filter (especially during low light or street shooting).
There are many effects and error corrections you can do in Lightroom, Photoshop, and other editing programs. One thing you can’t do is remove glare, like that on water or other shiny surfaces (glass, car bodies, etc). Think of adding a polarizer is like putting polarized sunglasses on your lens.
The same holds true for ND (Neutral Density) filters. It’s very difficult, if not impossible, to add that dreamy effect of moving water in post. Think of those photos you’ve probably seen of waterfalls, where instead of freezing the water, it appears to still be flowing. Or a seascape where the ocean seems to be flat and the clouds are soft and blended together. You need ND filters to create those effects. Essentially long exposure’s where if you were not using a ND filter everything would be blown out. Again, think of them as like adding dark sunglasses to your lens.. ND filters, mostly the variable type, are also invaluable for shooting video in brightly lit environments.
03-18-2026 03:21 PM
Suggest you look at B&W or Hoya.
03-18-2026 03:39 PM
Thank you, but that's over my head. Can you please just provide a recommendation for a UV filter for my Canon RF 85mm f/1.2 L lens? Brand, etc.? Why put an inexpensive filter on such incredible glass?
03-18-2026 04:00 PM
03-18-2026 04:06 PM
Excellent advice! Thank you.
Steve
03-18-2026 04:20 PM
Do you use any circular polarisers for your high-end lenses? And why?
Thank you, your experience certainly will help me,
Steve
03-18-2026 05:15 PM
It doesn't matter what the lens is, but yes, I will use CP filters in situations where I need to cut down reflections. Also very useful for example to enhance the look of plants in bright sunlight.
03-19-2026 10:48 AM
"There are many effects and error corrections you can do in Lightroom, Photoshop, and other editing programs."
I do use a B+W protecto filter on almost every lens I have. Otherwise, I use Photoshop as filters have almost become obsolete. Indeed most of them are totally obsolete.
"It’s very difficult, if not impossible, to add that dreamy effect of moving water in post. ... One thing you can’t do is remove glare, ..."
You need more PS training. 😊
03-19-2026 10:54 AM
Always keep in mind a filter comes off as easily as it goes on. If you find yourself in a situation where the filter is introducing some unwanted artifacts simply remove it. If you use a top brand and top quality filter like B+W there won't be many if any issues.
BTW, it is B+W, not B&W as some write.
