Reply
Highlighted
Occasional Contributor
Accepted Solution
I cannot view RAW images in digital photo professional.
[ Edited ]
All I can see after loading them is the number and a cross on the image. This is 7D mark11 software
Highlighted
Reputable Contributor
Re: I cannot view RAW images in digital photo professional.
What camera do you own and what version of DPP?
DCS 3c, DCS 520, D30, D60, 1Ds, 300D, 30D, 1000D IR, 7D, 6D, 6D, M5
15-45/3.5-6.3 IS, 16-35/4 IS, 22/2, 24/1.4 II, 24-105/4 IS, 50/1.4, 85/1.8, 100/2.8, 70-200/2.8 IS II, 300/2.8 IS
Highlighted
I own 7D mark 11 DPP came with the camera
Highlighted
Honored Contributor
Strange. Did it ever work? Download the latest software from here and see if that helps.
https://www.usa.canon.com/internet/portal/us/home/support/details/cameras/dslr/eos-7d-mark-ii
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
Highlighted
No has never worked this is the first time I have tried to transfer to DPP just bought the camera with the software
Highlighted
Honored Contributor
[ Edited ]
OK. So you downloaded files from camera card into a folder on your computer and then opened the folder in DPP and you get the "X" images?
DPP3 or DPP4?
DO you have another photo software that you could use to try to open the files; like Lightroom or Photoshop?
Highlighted
download from card reader to file then to DPP
Highlighted
Honored Contributor
Which OS?
If you click on file in the folder on computer what happens?
Highlighted
Honored Contributor
@jrhoffman75 wrote:
Which OS?
And is it a 32-bit or 64-bit OS?
And you still haven't told us whether you're using DPP 3 or DPP 4. If you don't know the answer or don't understand the question, you have some reading to do.
How old is the card reader, and what cameras did you use it with before you got the 7D2? The 7D2 produces large RAW files; it's conceivable that the card reader can't handle them and is losing part of the image. The "cross" figure (I assume you mean a gray field with two intersecting lines reaching the corners of the frame) means that DPP considers the image file to be garbled or incomplete. One way to test this is to use the EOS Utility (again there are two versions) to download the image files directly, bypassing the card reader. In some OSes that process can be tricky to set up, but it might let you rule out the card reader as the source of the problem.
Bob
Highlighted
I appreciate all your advice. You obvously know more about computers etc than I do. However I have an escuse I am 73. Nevertheless I seem to get round a problem given time. Once again thanyou for the help given me.
Dave Ward UK
powered by Lithium
