Reply
Occasional Contributor
Hazy whites 80D
I just got an 80D, to use as a backup to a 70D, or vice versa.
When shooting interiors on sunny days all the white light coming in from the windows looks blurry and hazy.
I've had do go EV -3 or even -4 to get decent non hazy whites, but then everything is too dark, and when you edit it on Lightroom, there's noise all over the place.
Veri frustrating.
Is this a known issue?
Am I missing somehting?
Thanks guys
Respected Contributor
Re: Hazy whites 80D
Raw samples?
DCS 3c, DCS 520, D30, D60, 1Ds, 300D, 30D, 1000D IR, 7D, 6D, 6D, M5
15-45/3.5-6.3 IS, 16-35/4 IS, 22/2, 24/1.4 II, 24-105/4 IS, 50/1.4, 50/1.2, 85/1.8, 85/1.4 IS, 100/2.8, 70-200/2.8 IS II, 300/2.8 IS
Reputable Contributor
Re: Hazy whites 80D
Not only would it help to have samples, but also the EXIF data and what your metering was set to - spot, centre-weighted etc.
What would be particularly helpful is to have comparitive photos taken by the 70d and the 80d using the same lens and same settings - of the same subject.
cheers Trevor
"All the beauty of life is made up of light and shadow", Leo Tolstoy;
"A good swordsman is more important than a good sword" Amit Kalantri
Technique will always Outlast Tech - Me
Re: Hazy whites 80D
Thanks. I'm away from my camera and laptop but will do soon
Re: Hazy whites 80D
Thanks. I'm away from my laptop and my 70d is in for cleaning. But I'll publish some examples soon
VIP
Re: Hazy whites 80D
"I've had do go EV -3 or even -4 to get decent non hazy whites, but then everything is too dark, and when you edit it on Lightroom, there's noise all over the place."
I am going to say that is a reasonable reaction to be expected. But we needs untouched samples as asked for.
Re: Hazy whites 80D
This board is not allowing me to import the raw originals, jpeg only. I've added the raws to this Dropbox folder:
https://www.dropbox.com/sh/nqimnzcu5bi31da/AAApwKRnfEI4sXseV9INQaH-a?dl=0
If you can't see the metadata (usually you can't on Dropbox), it's below.
All aperture priority, all partial metering.
Also, I've tried all sorts of editing on Lightroom, but nothing came close to fixing this.
IMG_110
ISO 250 - 10 mm - f/11 - 1/5 sec
IMG_116
ISO 200 - 13 mm - f/11 - 1/40 sec
IMG_126
ISO 200 - 10 mm - f/11 - 1/6 sec
IMG_183
ISO 160 - 14 mm - f/1 - 0.3 sec
IMG_192
iso 160 - 11 mm - f/11 - 1/5 sec
IMG_194
ISO 160 - 11 mm - f/11 - 1/30 sec
Re: Hazy whites 80D
[ Edited ]
IMG_110
IMG_116
IMG_126
IMG_183
IMG_192
IMG_194
It is due to dynamic range. Nothing wrong with the camera.
1. Use speedlites to light up the dark room.
2. Create a High dynamic range (HDR) image. 80D has multi exposure feature. You can multi expose and merge in camera (average). You will get a CR2 file that is almost like a raw file.
Below you have 0126, 0192 and 0194. I have used Hraw to visualize the sensor clipping in the highlights.
White means all channels are clipped. Green means green channel, blue means blue channel and red means red channel. Cyan means green and blue. Yellow means green and red.
When all channels are clipped (white) you will not be able to recover anything. If one or two channels are clipped you may be able to reconstruced some details in the highlights.
In my opinion, 0194 is better exposed than 0192 is due to the highlights. Yes, you have more noise in the shadows in 0194 but nothing that bothers. If you merge (HDR) 0192+0194, you will have less noise in the shadows (the TV) and you will still have less highlights clipped in the window.
Re: Hazy whites 80D
Thank you. I will try this.
(tried HDR merge in Lightroom and results weren't great, let's see if this HDR will work better)
I will also change the metering, in case "partial" was aggravating the issue
Re: Hazy whites 80D
Also, all shots were taken with not one but two Speedlites (430 slave to 600)
powered by Lithium
