11-09-2016
06:14 PM
04:11 PM
Hi all,
I've just bought a Canon EOS 1300D, and after taking a few snaps I'm eager to see how they've turned out.
I've downloaded and installed the relevant software for my Windows 10 (64 bit) computer, and then connected the camera to my PC via the supplied USB cable.
I can vouch for the USB port that I'm using, however I can't vouch for the cable as Canon use mini-USB whereas everything else I own uses micro-USB. But I'm positive, so I'll assume that the cable is working.
At this point nothing happens; Windows does not discover my camera, no drivers are installed (are any even required these days?), and I cannont access my photos ![]()
The EOS Utility software is set to launch when a camera is connected, further demonstrating that the camara is not talking to my PC.
Please can someone assist me if fixing this problem.
Thanks,
David
11-09-2016 06:20 PM
@duck__boy wrote:Hi all,
Thanks,
David
The usual reasons are that WiFi is turned on (which disables the camera's USB port) or that the USB cable is a "power only" model that lacks the data strands.
11-09-2016 06:20 PM
Thanks,
David
11-09-2016 06:21 PM
11-09-2016 06:24 PM
11-10-2016 06:20 AM
For the benefit of others, its spelled right out in the manual on the page "Downloading Images to a Computer".
11-10-2016 11:33 AM
11-10-2016 12:44 PM
A. I wasn't addressing you since you found out the answer yourself
B. I always provide reference back to a source document since others may not be as proficient as you and may need additional guidance.
01-14-2017 05:33 PM
As a matter of curiousity, is there a reason you don't just remove the SD card and read it via a card reader?
I never connect the camera direcly to my PC for a couple of reasons. The download speed seems to be faster with the card to PC direct, and I don't have to drain the camera batteries to transfer the files.
01-15-2017 03:07 PM
@Tronhard wrote:As a matter of curiousity, is there a reason you don't just remove the SD card and read it via a card reader?
I think there is a very simple explanation why many people want to use USB.. You're probably moving a LOT more data.
If you're only moving several dozen files, then using the USB cable is not only convenient, it is probably quicker than taking the card out, using a reader, creating folders, dragging and dropping files, and then re-inserting the card in the camera.
01-03-2025 04:09 PM
conon software is with out a doubt the worst software ever made. i have never had a worse expireanmce trying to get something to work. it is unintuitive,slow, and buggy at best. if I did not like the camera so much I would throw it in a lake. trying to connect to a PC via USB is like beating your self in the head with a hammer. you get it working it works a few times then just quits out of the blue, it wont tell you what the problem is, it just quits. canon you suck at this. please fire every person involved with the EOS software and start over, you have failed..
