12-31-2024
03:16 AM
08:11 AM
hi,
happy new year in advance
i was wondering whether it is more advisable to shoot in Clog or in a normal picture style with my EOS R5 ( or EOS R ) in a mixed lighting situation of artificial lights indoors and artificial lights outdoors
i understand that log is usually used when sufficient light is available otherwise the images may become noisy however i wonder what the specific advice is in relation to these two particular EOS mirrorless bodies
i usually shoot at iso 800 and almost always use an X-Rite ColorChecker Video colour chart to correct my images
i currently have the RF 15-35mm f2.8L IS U and the RF 24-70mm f2.8L IS U which i use for both photography and video which i am aware only open up to f2.8 however i do have EF primes such as the EF 24mm f1.4L, the EF 35mm f1.4Lii, the EF 85mm f1.4L IS and both the Zeiss Milvus f.14/50mm and EF 50mm f1.2L which i could use with an adaptor
thank you
12-31-2024 04:15 AM
C-LOG has greater dynamic range and that means you will possibly see more noise in the darker shadows that it can capture. Using a Picture Style has less dynamic range and this means that often the shadows a simply black rather than show the noise.
So this means that the question is more, do you need the dynamic range of C-LOG and the increased grading flexibility or the simplicity of a movie shot using one of the Picture Styles?
12-31-2024 05:14 AM
i come from a background of DSLR's and videocameras and a Sony Cinema Camera
we were advised to shoot the particular Cinema Camera, an PXW FS-5 in a picture profile rather than in slog ( in low light conditions ) because that particular cinema camera had a sensor that was not particularly sensitive to light but the Canon EOS R5 and R seem to do Okay at iso 800 and maybe iso 1000.
but given that i would colour grade the footage anyway even if it were shot in a normal ( standard ) picture style, i was wondering whether i would get better results in a normal picture style as log usually has a gamma curve that requires more light in order to hold the highlights which may be absent in darker, indoor or artificial lighting conditions
12-31-2024 12:13 PM
juiH,
Here is an article you might find helpful.
I don't begin to understand everything he is talking about, but you might find it helpful.
Steve Thomas
01-03-2025 07:20 PM
hi,
just a thought, would the performance of the 24 megapixel EOS R3 and R1 be significantly better in terms of video quality than the EOS R5 which i would prefer as if produces higher megapixel photographic output
i had hope for a 30+ megapixel successor to the EOS R which i have and actually like but somehow gave up and purchased my current EOS R5 as i found one in excellent condition at the second-hand store
in theory the 33 megapixel full frame sensor of the Sony A7C ii should produce good video though i have not tried it and do not intend to jump ship but if Sony can do 33 megapixels then in theory Canon could fill the gap between 24 megapixels and 45 megapixels whilst designing a camera that produces good video
01-03-2025 07:28 PM
i had a Canon C70 which produced lovely video with its DGO sensor but found that my RF 15-35mm and RF 24-70mm zoom lenses did not produce the appropriate zoom ranges on its Super 35mm sensor especially the 15-35
also, i am almost always a hybrid shooter so i found the cost of a video only device to be a serious disadvantage in terms of lost opportunities even though the Canon mirrorless cameras cannot match the output of a Canon C Line
