11-15-2024 09:56 AM
When trying to install EOSWebcamUtilityPro-WIN2.3 I received the following error "failed to correctly acquire vc_redist.x64.exe file: CRC error." I asked Chat GPT and it said the following but it did not resolve the problem:
"I'm sorry to hear you're encountering a CRC (Cyclic Redundancy Check) error while installing the EOS Webcam Utility Pro. This error typically indicates that the installation file is corrupted or incomplete. To resolve this issue, please follow these steps:
Re-download the Installer: The installation file may have been corrupted during the initial download. Visit the official Canon website to download a fresh copy of the EOS Webcam Utility Pro installer. Ensure that the download completes without interruption.
Verify the Download: After downloading, check the file size and compare it with the size indicated on the Canon website. If there's a discrepancy, the file may be incomplete or corrupted.
Disable Antivirus Software Temporarily: Some antivirus programs can interfere with the download or installation process. Temporarily disable your antivirus software and attempt the installation again. Remember to re-enable your antivirus after the installation is complete.
Run as Administrator: Right-click on the installer file and select "Run as administrator" to ensure it has the necessary permissions to install properly.
Check Disk for Errors: A CRC error can also indicate issues with your hard drive. Run the built-in Windows utility to check for and fix disk errors:
Install Microsoft Visual C++ Redistributable: The EOS Webcam Utility Pro may require specific versions of the Microsoft Visual C++ Redistributable. Ensure that the necessary versions are installed on your system. If not, download and install them from the official Microsoft website.
If after following these steps the issue persists, consider reaching out to Canon Support for further assistance."
Any Ideals how to resolve this issue???
11-15-2024 10:05 AM
Greetings ,
What troubleshooting steps have you performed?
What version and build of Windows are you using?
11-15-2024 10:48 AM
I solved the problem I needed both versions of windows visual studio.
WINDOWS USERS: We have identified an installation error occurring due to a recent update by Microsoft to the Microsoft Visual C++ Redistributables. To correct this issue, please download and install both of the following files from Microsoft manually:
After installing these redistributables, try installing our software again. Additionally, please note that we will provide an update to fix this issue shortly. We apologize for the inconvenience and appreciate your patience. Let us know if you need further assistance.
03-24-2025 10:43 AM - edited 03-24-2025 10:46 AM
I'm also hitting this issue.
I installed
vc_redist.x64.exe & vc_redist.x86.exe (V 14.42.34438)
Latest supported Visual C++ Redistributable downloads | Microsoft Learn
Windows Versions 24H2 (OS Build 26100.3476)
I tried on the following Canon builds and they all fail stating this dependency is not properly installed. I've reinstalled it several times from within the canon tool, directly from Microsoft page, and though the VS installer.
EOSWebcamUtilityPro-WIN2.3a
EOSWebcamUtility-WIN1.0
I've also tried running the install as admin.
03-24-2025 03:18 PM
Apparently, my new Surface Laptop has a Snapdragon, ARM processor. I downloaded the EOSWebcamUtilityPro-WIN2.3b package and now everything is working.
