G7x Mark III not showing image on eos webcam utility
ivansetiadi
After i re-install my PC my canon g7x mark iii not showing any images on obs only eos Webcam Utility text. It was working perfectly fine before i reinstall my windows. after googling the problems i think my pc didnt recognize it as a webcam. its detected as a "another device" for transferring files
Note: - im not installing any other eos apps this is a fresh installed windows only eos webcam utility
- i already disable wifi and bluetooth on my camera
Untitled.pngUntitled.png310298640_10221968534823426_7740711184016239061_n.jpg310298640_10221968534823426_7740711184016239061_n.jpg
19 REPLIES 19
i dont think my dummy battery is the problem, before i clean install windows it was working completely fine for like almost a year im using it as my regular webcam for my stream. But then after i clean install my windows it has no image on obs.
Things so far im doing for making this works :
1. Turning off wifi / bluetooth on my camera
2. Installing eos utility, and then close the eos utility and run the obs (still no image)
those 2 things still didnt work for me. and then today i clean install my windows AGAIN and the first thing i do before installing any other apps / drivers was installing eos webcam utility and obs. The image finally appear on obs but after i restart my pc, the image dissapear again and only showing "Eos Webcam Utility" texts
I keep forgetting.  PowerShots use ITU, Image Transfer Utility, not the EOS Utility.  We need to establish that you camera is communicating with the PC.
https://www.usa.canon.com/support/p/powershot-g7-x-mark-iii
Make sure that you have the latest versions of the firmware installed in the camera.  Use an SD card to install the firmware!
already running on latest firmware
311272523_10221990043161121_4167132310478284333_n.jpg311272523_10221990043161121_4167132310478284333_n.jpg
hi, can i connect my canon g7x mark 3 into elgato cam link 4k using usb c to hdmi cable?
canon g7x mark 3 (USB c cable) to elgato cam link 4k (hdmi)
No, you might damage the camera, your cam link, or both.
The EOS Webcam Utility is designed to use the USB port on the camera and the host computer.  It allows you to use your camera as it were a USB webcam.
is there any fix for my problems? i try everything but still not worked
Use the correct USB cable.
can you be spesific which kind of cable i should use? like is it 2.0 or 3.0 usb c cable? etc
This is what the camera uses.  Do not use cable adapters.
