EOS Webcam will not install EWCService.exe failed to start. Verify.....sufficient privileges
RichardZ
Enthusiast
Windows 10, fully updated as of 2/10/23.
I borrowed some text from another thread but it describes the problem in detail..
"It flat out refuses to install. I go through all the install process, it unpacks, goes through install progress bar comes close to complete, it hangs for several minutes and then pops up with
EOS Webcam Utility
! Service EWCService' (EWCService.EXE) failed to start. Verify
That you have sufficient privileges to start system services.
Retry/Cancel
Try retry all day long and it just repeats only option is to cancel"  .......which uninstalls the package.
I am administrator and right clicking and running the install as an administrator does nothing.
I have rebooted, updated the machine to the latest version available and installed GPEDIT.MSC and set privileges in it according to a web article.  Still does this and it will not install.
The log that is generated is useless.  The developer created an exception routine but didn't put anything in the log to say why the exception occurred.
37 REPLIES 37
My instructions do not include you trying to restart the service.  You are stopping it to complete the install.
As I said "Tried this and still get the same error."   So then I " So, I tried to manually start the service and no matter what state (automatic, manual, automatic (with delayed start) I could not manually start it.  Got a 1053 error, "The service did not respond to the start or control request in a timely fashion". ""
TheoSwart
I am having the exact problem.
I had OBS and EOS Webcam utility (ver1.22) under windows 10 on my laptop and it worked perfectly
then I had to replace the SSD.
I am trying to reinstall EOS Webcam utility (ver1.22) under windows 10 22H2
BUT
The installation does not complete and rapport the error:
“Service EWCService' (EWCService.EXE) failed to start. Verify That you have sufficient privileges to start system services.”
I tried installing three versions:
EOS Webcam utility (ver2.0.30) FAILED
EOS Webcam utility (ver1.22) FAILED
EOS Webcam utility (ver1.14) PASSED
Not sure if it is a Windows update conflict as I can install all three these version on my desktop under windows 10 22H1
I have finally tabled this.  There is some fine point in the install process that they have missed.  If I find a solution I will post it.  Thanks for the info!
Hey there Jeremy, I sure do hope you are able to help me out especially since you have worked at windows support my Laptop is currently running widows 11 and we have been trying to download the webcam utility pro app for about the past 7 hours and we keep getting the EWCServie.exe failed to start. verify that you have sufficient privileges to start system services.. I've looked around quite a bit to see what fixes have worked for other people and I've even tried downloading the 1.1 but that has not worked either . Can someone please help us with this..
Exotic_A1Pets
Hey there Richard how did you set the privileges can you share the link or steps please we have been at this for about almost  hours now and have not had any luck getting pasted that failed to pop up screen
Did this to manually start EWCService but then got error code 1053
I also got to that point.  I think that the privileges error is not accurate and there is some fine point that has been missed in the software package.  This is from an earlier post of mine "Tried this and still get the same error.   So, I tried to manually start the service and no matter what state (automatic, manual, automatic (with delayed start) I could not manually start it.  Got a 1053 error, "The service did not respond to the start or control request in a timely fashion".  So based on Googling I ran an sfc /scannow but no errors were found.  The next step will be to edit the timeout in the Registry and see if it is set properly.  At a loss beyond that.  I see that a couple of others are now reporting the same problem with much newer machines."
RichardZ
Enthusiast
So, with no changes made by me to the machine or operating system, today I downloaded the latest version of the webcam utility and ran it full expecting it to fail during installation.  Much to my surprise it has successfully installed.  Now I need to reload software to see if it works!  Not enough time today but will let everyone know if I get it to work.  At least one step in the right direction!!!!!
