EOS Webcam Utility (2.1.18) not working with MS Teams 2024
macbook-amateur
I've been using the paid version of EOS Webcam Utility Pro (2.1.18) to stream over Teams until today. After updating Teams to the most recent "version 24004 (24004.1204.2655.7488)" EOS Webcam Utility no longer recognizes Teams is actively streaming my camera.
It's not a Teams issue, as Teams still displays EOS webcam utility feed as it should, albeit the "off air" fallback image. You can see this in a side-by-side screenshot here: My camera is active in EOS on the left. Teams is actively streaming the EOS feed on the right, but EOS doesn't understand the stream started yet.
Please advise on steps to remedy, or confirm this is an active bug you are tracking with EOS Webcam utility (2.1.18)
Thanks.
MBA
15 REPLIES 15
Thanks Natalya. I confirmed that there are no other applications running that would need to use the camera and it is still not working. I'll note in the past; however, this wasn't an issue.
msoverland,
Have you tried disabling the integrated webcam? Something about the presence of more than one camera seems to cause problems. I found anther issue where this was the case. 🎥
-Tony
Hi Tony, I've disabled the camera notifications in the Terminal. How do you disable the integrated webcam?
In  MacOs Security and Privacy settings, you'll have to disallow the Integrated Webcam access to all programs.
Screenshot 2024-03-26 at 11.53.13 AM.pngStill no dice. Did that then Restarted and you can't use any camera in Teams or any other app.
Shucks!
