EOS R50 Webcam using HDMI with OBS
boboosta
I just got an EOS R50 camera. The R50 has both USB-C and HDMI (micro) ports. I want to use it as a webcam at 1080p resolution using OBS software. I know I can connect it directly to a computer using USB-C. However, my computer is old, and it lacks USB-C. It has only USB-2 and HDMI ports.
What's the best way to connect it?
Will any of these methods will work? Can I get 1080p resolution at 30fps?
1. Connect from R50 USB-C to USB-2 using USB-C-to-USB-2 adapter.
2. Connect from R50 HDMI to computer HDMI.
3. Connect from R50 HDMI to HDMI port on a capture card (e.g., Enigma).. Then connect from capture card's USB-2 port to computer's USB-2 port.
6 REPLIES 6
Anonymous
Not applicable
I believe a USB type C connector on one end and a type A connector on the other end would work. It should be fairly inexpensive to try it.
I believe that you are calling a USB type A a USB-2 port.
Sorry about that. Let me be more precise. There are USB standards which determine the maximum speed, There are also USB ports/connectors. Each standard typically uses a specific subset of ports. My computer’s input is USB standard 2.0 (which has a maximum speed of 480bps) and port type 2A. However, I suspect the connection might not work unless it uses USB 3 or 4. A Type C port typically uses USB 3 or 4.
Anonymous
Not applicable
For the price of a cable, try it.
I agree, Bob. But it is possible that, if the OP's system is pretty old (as stated), it could be USB type A version 2. I think most modern systems that still have USB type A are version 3.0 or 3.1. I know that a lot of stuff I have seen and bought lately that uses USB type A says it's ver. 2. Kind of surprising, but they work on my system that's all type C thunderbolt, which is backward compatible. You just don't get the full speed of type C or thunderbolt.
@boboosta, as Bob said, a cable with USB type C on one end and type A on the other should work.
Newton
Thanks. I’ll give the cable a shot.
Sorry, boboosta, I was typing while you had already responded 🙂
However, I think you will be fine going from USB C on the camera to USB A ver 2 as it should be backward compatible (from camera). As mentioned, you may loose some throughput, but hopefully it won't be problematic.
I would like to know, so please report back. I don't mind eating a little crow from time to time 🙂
Newton
Friends and Family
