02-18-2021 11:58 PM
Hey there guys, Im using the Canon EOS 200D Mark II with the Canon Webcam Utility. However it disconnects quite often.
Ive tried many ways to prevent that error (change battery, change usb cable, change usb port, reninstall software) . However it still occurs at any random time during streaming.
Is there any way I can atleast replace the error message image with some custom image?
02-19-2021 11:56 AM
Can you change the image? I seriously doubt it. I believe that little Red X means the computer does not detect a camera connected to a USB port.
Is your camera in Movie Mode? What streaming app are you using?
02-19-2021 11:54 PM
On the mac, if you could actually find the application (It only puts an uninstaller in the apps folder) you might be able to open the package contents and change the image.
02-20-2021 05:03 AM
@kvbarkley wrote:On the mac, if you could actually find the application (It only puts an uninstaller in the apps folder) you might be able to open the package contents and change the image.
You're assuming that the "offline image" is a separate file, and not an embedded resource, which is infinitely more secure.
02-20-2021 09:02 AM
Its in Movie Mode and I use OBS Studio. The webcam utility works normally most of the time. But sometimes it disconnects or the camera itself crashes with the dreaded Error 70. Thats when this error image appears.
02-20-2021 09:03 AM
Im using Windows 10. Ill browse through the installed location and check though.
01-26-2022 08:47 AM
C:\ProgramData\Canon\EOS Webcam Utility
