06-28-2023 08:05 AM
Hello, I've got Canon Rebel T6 (EOS 1300D) and wanted to use it as a webcam. I connected the usb cable that I got with camera but there is no video output at all. Turned on eos webcam utility and the only thing thats there is the default scene it doesnt see the camera? I turned camera mode to video so it should work. Also can't connect over WIFI as its premium option and im not looking forward to get it as the only thing I need is cable one. It tells me to connect the camera but it is connected? Tried also many other cables with no luck.The graphic that is there always and no video
06-28-2023 09:40 AM
You do not appear to be running the EOS Utility, but if you are, it will keep the camera from working as a WebCam.
If you have Wi-Fi enabled on the camera, it will disable USB connectivity.
With the camera connected via cable and powered on, does it appear in Windows explorer as a Mass Storage Device? Can you open the folder and view images on the camera?
Have you looked at Device Manager. Does the camera appear there when connected and powered on?
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
06-28-2023 09:40 AM
06-28-2023 09:52 AM - edited 06-28-2023 10:03 AM
To add to what Rick has already asked, what version of the WebCam Utility are you running?
What app are you trying to use?
If you do not have subscription for Webcam v2 Pro, then which camera did you select?
[EDIT]. FYI, your posted screenshots are totally meaningless, to me.
06-29-2023 09:47 AM
Hi as shadow said it was wifi enabled problem so the ports were turned off thank you sm for help now it works
06-29-2023 10:06 AM
Thanks for your feedback. One of us would have got you to the finish line 😀
