05-30-2016 01:20 PM
The LCD on my Canon T5i goes black when HDMI or mini USB is plugged in. Thoughts?
05-30-2016 01:43 PM
@sharpt wrote:The LCD on my Canon T5i goes black when HDMI or mini USB is plugged in. Thoughts?
Merely "plugged in", or do you mean when something is connected to the other end, too?
What does your instruction manual say about it?
05-30-2016 04:16 PM
Merely plugged into the camera
05-30-2016 04:18 PM
@sharpt wrote:Merely plugged into the camera
Okay. I'm pretty sure that is normal behavior for both ports.
05-30-2016 02:44 PM
If you plug in an HDMI cable camera assumes you want to display on TV so it shuts off LCD.
05-30-2016 04:17 PM
It does display on the TV (though not camera) but then it doesn't convey audio - through either mini USB/RCA or HDMI. Is there a setting to fix these problems?
05-30-2016 04:23 PM
@sharpt wrote:It does display on the TV (though not camera) but then it doesn't convey audio - through either mini USB/RCA or HDMI. Is there a setting to fix these problems?
Those are not "problems", not at all. I'm not sure if the T5i even has "Audio Out". First and foremost, it is a still photo camera, not a video camera, which is a different device from a camcorder.
05-30-2016 04:30 PM
I've been viewing YouTube videos to monitor headphones. Several explain how that can be done with the mini USB out to RCAs to a mini plug (sometimes with an amp between).
https://www.youtube.com/watch?v=NZwBeeYCDlU
https://www.youtube.com/watch?v=BnEtj5l3acs
Canons appear to be used in some of those videos. Also if you're not able to send audio through either of these cables, why do the ports exist?
05-30-2016 04:23 PM
05-30-2016 05:47 PM
