03-18-2014 05:36 PM
03-18-2014 05:36 PM
03-18-2014 06:54 PM - edited 03-18-2014 06:55 PM
By "shutter locking up" I am assuming you mean the camera just refuses to fire.... that the shutter won't operate (There are also ways of doing " mirror lockup" to prevent camera vibrations during longer exposures, and you "lock open" a shutter to clean the image sensor... but it doesn't sound like these are what you're concerned about.)
I don't have that camera but I wonder if it's possible, just guessing from your description, if that there is some sort of "focus lock" going on?
What "focus lock" or "focus trapping" does is prevent the camera's shutter from releasing until focus is achieved. This can be useful for some types of photography, but could be a problem for others, including sports. How fast the camera will focus and whether or not it can effectively track a moving sports subject depends upon the lens being used and how the camera is set up.
How do you have the camera set up? Are you using one of the scene modes or what exposure mode? Which Focus mode have you selected?
Try setting the camera to "P" and, for sports (or any moving subject), AI Servo focus mode. Then select only the center AF point. You'll have to be careful to keep that focus point right on the subject, right where you want the lens to focus. Half-press the shutter release to start focusing (metering and, if the lens has it, IS will start too). Track the subject and fully press the shutter button any time you want to take a shot.
Be sure your shutter speed is fast enough to freeze action. If not, increase the ISO setting.
Hopefully this will work.
If you are shooting a stationary subject, switch to One Shot focus mode.
For a more complete description of the Canon AF system, watch this half hour video on YouTube, and the two others in the series. I don't recall if they specifically discuss your camera model, but much of what they talk about applies to all Canon cameras focusing systems.
Alan Myers
San Jose, Calif., USA
FLICKR & PRINTROOM
03-19-2014 09:22 AM
Thank you for responding! I've tried sports mode, program mode, and full auto and that didn't matter...the shutter would still close on me (lock up) and wouldn't release. Very similar to making a long exposure type closing of the shutter. With shooting my sports images, I shoot at 400 ISO because my lighting can change quickly late afternoon but still allows me to make enlargements. I still have plenty of light so the shutter speed isn't the problem on any mode.
I know I'm on single shot mode but I haven't messed with the focus lock. I'll try that this weekend and see if that helps. If that doesn't work I will assume this is a one in a million camera/lens flaw and see if I can swap it out.
03-19-2014 12:06 PM - edited 03-19-2014 04:36 PM
If the camera has a "focus lock" or "focus trap" setting, you must turn it off. I don't know if a T3 has that feature, though.
If the sports involve any sort of movement, you have to use AI Servo focus, not One Shot. One Shot is only for stationary subjects. In One Shot mode, as soon as focus is achieved, auto focus stops and locks. If a subject is moving, it will go out of focus and One Shot cannot correct for that. AI Servo, on the other hand, focuses continuously, as long as you keep the shutter button half-pressed and an active AF point on the subject you want focused. It never stops and locks, the way One Shot does.
In order to better understand the AF system of Canon cameras, I recommend viewing three half hour videos on YouTube, beginning with this one. These videos cover a variety of Canon camera models and there are some differences between them, but you will likely find info relevant to your camera.
Besides focus, there are other possiblities... However, first thing to note is that the shutter doesn't close when you press the shutter release button, it opens. The shutter is normally closed, only opens momentarily to make the exposure. If you are seeing the viewfinder go dark (which is due to the mirror flipping up, not because "the shutter is closing") and no image is being taken, there are a couple things to check....
1. Do you have "mirror lockup" engaged? This feature is on most Canon cameras I'm aware of and is turned on in the menu. It's used to flip the mirror up in advance of taking a longer exposure, where the vibration of the mirror "slap" might cause shake blur in the image. Once it's engaged, you press the shutter release once to raise the mirror, then a second time to take the image.
2. Have you accidentally put the camera into Live View mode? This lifts the mirror immediately and what's being seen via the lens is then displayed on the camera's rear LCD screen, real time. Accidentally starting Video recording acts similarly.
3. Long exposure noise reduction is another feature that can be enabled or disabled on many Canon. It doesn't sound as if you are using long exposures, however just so you know, when LENR is on, the camera actually takes two images. First is the long one you set up, the second is equal length but with the shutter closed... a "dark image" that's used to identify noise to be deducted from the first image. Problem is, if you don't realize what's happening and cancel the second image (by turning off the camera, for example), neither the second or first images are saved. So you end up wondering what happened to your shot. But, again, this is not likely to be what you are encountering, because it sounds as if you are shooting in good light and using fast shutter speeds where LENR wouldn't occur, even if it's turned on.
I wouldn't worry about using higher ISO... 400 is about the lowest I use with sports shooting, unless I am going for slow shutter speeds and "action blur" effects. You should try 800 and even 1600. If shooting in the shade, I'll sometimes use 1600 even in broad daylight.
I would steer clear of Full Auto and Sports modes. Instead I'd suggest using P or, even better, Tv. These are still full auto exposure modes, but they don't impose other limitations on you (such as forcing you to shoot JPEGs instead of RAW files, and/or limiting the focus modes you can select).
Hope this helps!
Alan Myers
FLICKR & PRINTROOM
