Exposure simulation and lines on Live View
Tintype_18
Looked through the PDF manual but couldn't zero in on anything specific. Two items here.
1. I was taking some shots of the moon last night. Camera was set on Av- 2/5 sec., f/5, 110mm, ISO 3200 (Auto). The Exposure Simulation icon was flashing. Found this in the manual but nothing why it was flashing. Did I over look something?
2. The Live View showed two vertical lines on it but they aren't on the photo in File Explorer.
As always, your help is most appreciated.
Two months ago, I couldn't spell Fotografter. Now I are one! Smiley Very Happy
John
11 REPLIES 11
Moderator
Moderator
Hi, Tintype_18!
So that the Community can help you better, we need to know exactly which Canon camera model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
My oversight. Canon EOS Rebel T7 1500D. Will get the rest of thei info later today.
John
The moon photo was taken with a Canon EOS Rebel T7 1500D. Settings are: Av, 2/5 sec., f/5, 110mm, ISO 3200. Unedited photo attached.
John
Tintype,
Not sure about the lines but the exposure flashing was probably issuing a warning that the moon was overexposed.
The moon is completely blown out from overexposure and looks like the sun doing a partial eclipse.
I would suggest lower ISO and faster shutter speed.
Attached images were shot with Canon 1DX III, the first with an EF 800 f5.6 lens and the second with a Celestron 1100HD telescope
The first shot using the EF 800 was shot at f7.1, 1/160, ISO 100; the second is with the telescope which is equivalent to 2800mm, f10 and was shot at 1/800, ISO 1250.
I would fix your ISO at a lower value and use a shorter exposure.
Rodger
Many thanks, Rodger. I might have set ISO to Auto out of hesitation to have a specific setting.
Those are great shots. I can see Whats-his-name's golf ball. Looks like he will need a sand wedge to get out of the crater to salvage par.
Edit- Will look at conditions tonight. Will take a photo with your suggestions in mind.
John
I think exposure sim flashing means that it can't create a simulation of the exposure, because it is too dark or some other reason.
From my T6S manual:
If you want the moon properly exposed, and everything elsee dark, use the looney 11 rule:
https://en.wikipedia.org/wiki/Looney_11_rule
If you want it all exposed correctly, you will need two shots, one for the moon and another with the foreground and merge them in post.
Yes, manual exposure as indicated above.
The moon is a very small part of the frame, so the camera is going to base exposure on the majority of the frame, which is dark sky.
FWIW, tried a couple of shots last night. Photos were blurred and deleted. Looks like today is cloudy so might not get any shots tonight. I recall a thread about photographing the moon. Will find it and read it.
Thanks to all!
Edit: Did a search and found this from a previous post. Need to take time to go through it. So much to learn for one photo!
https://photographylife.com/landscapes/how-to-photograph-moon
John
