07-30-2017 11:00 PM
Was wondering if this combo is compatible to use a the camera's flash as a slave to fire the 430 wirelessly. I just dug into the menus of both devices and its looking like its not.
Can anybody help me out?
Thanks in advance.
07-31-2017 08:45 AM
@HorHey9000 wrote:Was wondering if this combo is compatible to use a the camera's flash as a slave to fire the 430 wirelessly. I just dug into the menus of both devices and its looking like its not.
Thanks in advance.
The camera's built in flash would have to be the Master. I don't recall seeing that as a feature of the SL2.
10-18-2017 06:28 PM
Hi HorHey9000,
Thanks for posting.
The internal flash on the EOS Rebel SL2 cannot be used as a master flash for Canon's Speedlite External flash units..
10-19-2017 10:10 AM
Hold the reins there Tonto. There may be a work around.
See if an optical slave can be triggered by the SL2 built-in flask. They are fairly cheap and easy to use.
10-19-2017 10:19 AM
Just make sure to get one that ignores the ETTL-2 preflash. IIRC, the SL2 has *only* ETTL-2, no manual without the preflash, which also means you need to go through hoops to prevent the SL2 flash from affecting the shot.
10-19-2017 10:19 AM
