t7i & off camera lights?!?
arobertsonphoto
Hey Hey!
We have a t7i we are trying to use for a photobooth.  We're attempting to connect it to an AlienBee strobe with, with a hotshoe adapter and a cord. However, no matter what adapter or cord we use, the camera WILL NOT trigger the flash.
The menu system shows this (below) when the hotshoe adapter is attached, AND when there is nothing attached.
When I attach a flashpoint speedlight to the camera, it has no issues. I can access the menu, the flash fires, all is well.
Please help!
You don't have a center contact. You require an E-TTL flash that talks to the camera via the other 4 pins.
13 REPLIES 13
kvbarkley
VIP
VIP
Does your T7i have the center flash contact?
What does AlienBee say?
I'm not sure what you mean by center contact, but here's a photo!
**facepalm** that makes sense. Do you have any reccomendations for a hot shoe adapter that will work?
No, I just use Canon Equipment. And, my T6S has the center contact. 8^)
FWIW, that doesn't look like a T7i. The T7i has a center post, the T7 doesn't.
Waddizzle
Hey Hey!
Please help!
The camera in the above image seems to be a T7.  It is definitely not a Rebel T7i.  Note the button in lower right corner.
"Fooling computers since 1972."
I just took him at his word. 8^)
I'm a she 😞
