07-27-2021 01:27 PM
Hey Hey!
We have a t7i we are trying to use for a photobooth. We're attempting to connect it to an AlienBee strobe with, with a hotshoe adapter and a cord. However, no matter what adapter or cord we use, the camera WILL NOT trigger the flash.
The menu system shows this (below) when the hotshoe adapter is attached, AND when there is nothing attached.
When I attach a flashpoint speedlight to the camera, it has no issues. I can access the menu, the flash fires, all is well.
Please help!
07-27-2021 01:59 PM
You don't have a center contact. You require an E-TTL flash that talks to the camera via the other 4 pins.
07-27-2021 01:42 PM
Does your T7i have the center flash contact?
What does AlienBee say?
07-27-2021 01:48 PM
I'm not sure what you mean by center contact, but here's a photo!
We haven't reached out to AlienBee, that didn't occur to me.
07-27-2021 01:59 PM
07-27-2021 02:05 PM
**facepalm** that makes sense. Do you have any reccomendations for a hot shoe adapter that will work?
07-27-2021 02:27 PM
No, I just use Canon Equipment. And, my T6S has the center contact. 8^)
07-27-2021 03:03 PM
@arobertsonphoto wrote:I'm not sure what you mean by center contact, but here's a photo!
FWIW, that doesn't look like a T7i. The T7i has a center post, the T7 doesn't.
07-27-2021 05:47 PM
@arobertsonphoto wrote:Hey Hey!
Please help!
The camera in the above image seems to be a T7. It is definitely not a Rebel T7i. Note the button in lower right corner.
07-27-2021 07:25 PM
I just took him at his word. 8^)
07-27-2021 07:44 PM
I'm a she 😞
